Nueva versión del 23 de diciembre!!
La release note:
1. Still same NMT apps 00-17-091216-15-POP-402
2. NTFS driver update, now supporting NTFS write
3. Added support for mkv prepend compression for h264 tracks
4. Extended unicode string support for Hebrew Right-To-Left.
5. Fixes for music Now Playing screen
- Cover art image now is up to 2MB. Otherwise default image is shown
- Fixed issue with image containing EXIF
- Scale down large image when necessary for proper display.
6. Fixed ID3 parser byte-skipping error that caused long delay when music playback.
7. Added shuffle feature on music playback (all types of audio files)
- Use Repeat key to toggle
- only for music playback
- does not work on UPnP or myiHome, works for SMB/NFS
8. Fixed issue where Infobar is cleared when play next file in a playlist.
9. Fix for WiFi issue: WPA-PSK / WPA2PSK[TKIP+AES] connection failure
10. Reset subtitle settings when doing factory reset.
11. Minor modification to IDX/SUB rendering
12. Minor tweak for MKV DTS drop out issue.
