Último firmware BETA de PCH A-100 - 16-03-2010
mercucho1 dijo:
como va el tema de los firmware? ya han sacado alguna RC?? Q llevamos ya mas de un mes sin firmware nuevo!!
Betas han salido un par, lo que pasa es que añaden funcionalidades un poco "tontas" y ni siquiera las he probado. La última es esta:
Firmware 01-17-081023-15-POP-402 (00-17-081023-15-POP-402 Apps) RC4
1. Requires NMT apps 00-17-081023-15-POP-402
2. Rectified "repeat", "suspend" key mapping in ISO playback
3. Fixed "request cannot be processed" occured in previous RC.
- may still occasionally occur after DVD play from DVD-ROM; to be fixed.
4. Standby LED output fixed
5. Fixed failure to access Clutch interface
6. Fixed incorrect playlist OSD display when music playback from myiHome
7. Fixed decoder crash when playing a MKV without audio track
8. Fixed reset to factory settings occasionally failed after network configuration changed
9. Fixed incorrect downsampling of PCM audio for HDMI output source sampling rate > 48kHz
10. Fixed incorrect WAV playback sampling rate (set at 48kHz)
11. Fixed broken browser history
Nueva beta con algunas mejoras muy interesantes, como el 'bookmark' y el 'Auto framerate':
Salu2
1. New NMT apps 00-17-081030-15-POP-402
2. Browser
- Improvement on font engine character rendering (30% speed up)
- local drives faster navigation
- press item number (using numeric key) will jump to the page where the item is located
3. Hebrew translation added
4. New Web Services UI
- customizable icon feature with browse image utility (need NMT apps)
- Known issue: Translation incomplete
5. Improved SMB server startup time
6. Improved browsing time for SMB client.
7. Video playback
- Bookmark/resume for mono single playback (only one at moment)
- Auto framerate synchronisation
- VCD *.DAT playback fixed using soft demux
- Removed up/down keys as prev/next track
8. Atheros USB WiFi stability fixes
9. Fixed HDMI display output blackout issue for auto EDID
10. NDAS support
- Known issue: cannot run with NMT apps running; fixing
11. Discrete RC (Logitech) scancode fix
12. Fixed Hebrew SRT subtitle containing invalid character
13. Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed
14. TV Type setting for DVD playback
- the TV type setting is now working for DVD video playback
(4:3 and 16:9 only, 16:10 will treat as 16:9)
15. DVD Menu
- new popup menu if MENU key on PCH remote controller is pressed
- user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu
16. SMB client fixes
- Fixed name query hostname resolution picked up wrong IP address from the IP list
17. Updated network share and webservices language packs.
18. Webservices, bug fixes on customizable service icon with browse feature.
19. Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt
20. Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC)
21. Disable incorrect video MPEG1/2 VBR display.
22. Fixed incorrect framerate info for video playback (*.mov, *.mp4).
23. Fixed subtitle parsing with BOM (UTF8 support only)
24. Fixed video bitrate calculation error (less 1 packet every second)
Y en que consisten el 'bookmark' y el 'Auto framerate'.
¿El "auto framerate" significa que si reproduzco una pelicula a 1080p y 24p la salida HDMI se pondría automaticamente a 1080p/24p? porque sería un puntazo.
El 'bookmark' (marcador) significa que si lo tienes activado, cuando dejes de ver una película a medias, la próxima vez empezará a reproducir desde el punto que la dejaste. De momento sólo se permitirá un 'bookmark' pero en el futuro se podrán poner varias marcas para diferentes películas.
El 'autoframerate' (tasa de refresco automática) no te cambia la resolución, sino el refresco de manera automática, tomando la información de la película directamente. Tendrá 3 opciones: Desactivado, PAL/NTSC y PAL/NTSC/24.
PAL/NTSC te cambiará entre 50/60 Hz. y PAL/NTSC/24 te cambiará entre 50/60Hz o 24 fps. (23,976 para ser exactos).
Salu2
Juanramon dijo:
Salu2
Pues son características muy interesante, sobretodo la del "autoframerate" porque es muy incómodo tener que cambiar la frecuencia según la película que estés viendo.
¡Muchas gracias!
En la última beta (la 4), han incluído la posibilidad de tener hasta ¡10 marcadores! :LOL:
Al pulsar 'Stop' el fichero queda marcado en la lista de ficheros. Si hacemos 'stop' en un undécimo, el primero se desmarca.
Salu2
No tengo problemas con el rate de bajada si te refieres con esto a la velocidad de transmission, si hay suficientes peers el bajar a 300-400Kbps es habitual.
Victek dijo:
a mi de 50kbps no pasa, mientras que con el btpd si que llega a 200kbps. Bueno, cuando saquen la siguiente versión volveré a probar a ver que tal...
mercucho1 dijo:
Victek dijo:
Creo que en el último firmware se han cepillado el transmission y han dejado únicamente el btpd. De hecho algo comentan respecto a que debes terminar de descargar todos antes de instalar el firmware...
juju666 dijo:
Vamos!! q fuerte me parece!! :| La pega q tiene el btpd es q ya no está en desarrollo, y q esteticamente necesita un lavado de cara, pero por lo demas funciona "estupendosamente"
Por cierto, por el foro oficial hay rumores q dicen q están preparando una interfaz para que se vea transmission desde el PCH sin necesidad de encender el ordenador, así como nueva versión especial optimizada para NMT ¿?¿?¿? rumore rumore, veremos a ver en q acaba todo esto
mercucho1 dijo:
juju666 dijo:
Perdón, era al contrario:
Release Version : 00-17-081127-15-POP-402
Release Date : 27 November 2008, 19:04 +8GMT
Remove btpd, use transmission as default BT client
Hacía algún tiempo que no actualizaba el post, he puesto un compendio de las funcionalidades y mejoras de las versiones beta. Muy pronto saldrá como release oficial.
Ha salido la RC1 (Release Candidate 1), con algunas pequeñas mejoras, como soporte subs IDX/SUB. Es una primera implmentación por lo que probablemente este soporte no salga todavía en la siguiente versión final.
Actualizo post original.
buenas! Parece q esto ya no sufre actualizaciones al mismo ritmo que al principio. La verdad es q ya van bastante bien los cacharros estos. ¿Sabeis si se cuece algo interesante para las futuras versiones?
En estos momentos tienen todos los recursos dedicados a un nuevo modelo que parece ser será un complemento del A-110, por lo que las actualizaciones están un poco paradas, pero volverán a salir.
El viernes 29-5 salió una beta para el A-110 con pequeños arreglos para 3 bugs. Esta semana saldrá una final para el A-110 y el A-100.
1. Fixed MKV DTS audio drop issue.
2. Fixed playback of BD-ripped M2TS (eg. movie "Taken") from HDD causing system crash.
3. Fixed formatting SATA HDD with greater than 1TB capacity issue.
Salu2.
Juanramon dijo:
uuuuuuuuuuuuuuuuuuh, ¿pero es un nuevo modelo de popcorn o es un accesorio para el a110? ¿que función tiene? cuenta cuenta... :sneaky:
