Nuevo firmware estable A-110
Os informo que ya ha salido la última versión estable del firmware para el popcornhour A-110
Lo podeis conseguir tanto en la página de popcorn como en la opcion de mantenimiento de vuestro popcorn
dandole a buscar actualizaciones.
Copio y pego las novedades y mejoras (en inglés):
Release Date : 26 February 2009
Firmware Version : 01-17-090125-15-POP-403-000
1. Requires NMT apps 00-17-090115-15-POP-403
2. Browser / System
- Improvement on font engine character rendering (30% speed up)
- faster navigation on local drives
- Use numeric key to input item number to jump to the page where item is located
- Improved fileplayer speed
- Hebrew translation added
- Fixed HDMI display output blackout issue for auto EDID
- Discrete RC (Logitech) scancode fix
- Updated network share and webservices language packs.
- Removed EXT2 option for NMT installation
- Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly
- Additional symbols can be input from "1" key
- HTTP download manager (only works with links with special "download" attributes.
- File player hide Recycle Bin folder
- Fixed 'TV MODE' + '3' key handling bug
- Fixed recovery kernel no red screen displayed
- Browser image caching fix, should fix some YAMJ crashes or no image issue.
- Fixed HDD spin-up during standby
- Fixed slow loading of HTML pages
4. Web Services
- New UI
- customizable icon feature with browse image utility (need NMT apps)
- bug fixes on customizable service icon with browse feature.
- Web Services page modification
- Fixed a "save/remove service" bug
- Now able to customise JPG/BMP icon
- Fixed slow IR response while playback Internet Radio
- Immediate response to STOP during Internet video streaming
- Fine-tune Web Service UI
5. Network
- Improved SMB server startup time
- Improved browsing time for SMB client
- Atheros USB WiFi stability fixes
- Fixed SMB client hostname resolution picked up wrong IP address from the IP list
- Fixed file copy failed from HDD to SMB/NFS with names containing whitespace
- Fixed UPnP AV server playall issue broken in previous release
- Fixed Samba server halts after device name change
- Torrent client is now by default Transmission (btpd removed)
**** IMPORTANT NOTE: Please ensure completion with previous downloads with BTPD,
as new Transmission client cannot inherit previous downloads.
- Fixed torrent schedule page not working
- Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list
- Atheros USB WiFi added support for TP-Link v2 stick
- Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc)
6. Playback
- Bookmark/resume for single playback
- 10 bookmarks available now
- Press stop to bookmark the last video playback
- Press enter / play with focus on bookmarked clip to resume
- Press "0" to start from beginning of clip
- Auto framerate synchronisation
- Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC)
- switch to NTSC(60Hz) when selected mode not applicable.
(previously, it will follow TV mode selected)
- Use 59.94 for NTSC when matching content detected.
- Fixed incorrect data shown on infobar.
- Fixed after ISO playback, screen goes blank when framerate sync kicks in
- Improved info display
- Disable incorrect video MPEG1/2 VBR display.
- Fixed incorrect framerate info for video playback (*.mov, *.mp4).
- Fixed video bitrate calculation error (less 1 packet every second)
- Modified infobar UI (height, spacing and text displayed)
- Fixed info bar losing text after paused
- Improved accuracy of mpeg1/2 bitrate information
- Photo app
- Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed
- Fade-In Fade-out effect added for photo transition
- Enable large jpeg rotation. (downscale before rotate)
- Fixed faded color for jpeg at 360-deg rotation
- TV Type setting for DVD playback
- the TV type setting is now working for DVD video playback
(4:3 and 16:9 only, 16:10 will treat as 16:9)
- DVD Menu
- new popup menu if MENU key on PCH remote controller is pressed
- user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu
- Modified progressive zoom and pan in ISO/IFO playback
- Removed up/down keys as prev/next track
- VCD *.DAT playback fixed using soft demux
- Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt
- Improved handling of MKV H.264 profile and vlevel.
- Fixed cannot stream MPEG from UPnP AV server, liveTV
- Fixed *.pls file unable to start when playback locally (HDD/SMB/NFS)
- *.m3u playlist supported.
- Fixed TS with stream6 as teletext playback cause out of memory
- Fixed MKV H264 L4.1 pixelated video issue
- Fixed ISO over SMB stutters when no HDD attached
7. Subtitle
- Fixed Hebrew SRT subtitle containing invalid character
- Fixed subtitle parsing with BOM (UTF8 support only)
- Thai subtitle support
- Fixed wrong character rendered in Thai subtitle
- Changed default subtitle font size to 28 and Y offset to 10
- Exception handling in SSA subtitle parsing
- Slight adjustment of subtitle position
NMT Apps Version : 00-17-090115-15-POP-403
Release Notes :
1. Minimum firmware version to use this NMT App is 00-17-090116-15-POP-403
2. Improved on samba client browsing time and server boot up time
3. Fixed occasional slow samba response
4. Upgraded to nzbget 0.51
5. Upgraded to nzbgetweb 1.2 (Categories can be modifed in /mnt/syb8634/nzbgetweb/setting.php5)
6. Various Casgle fixes
7. Fixed FTP password saving
8. Improved Setup Page loading time
9. Remove btpd, using Transmission as default BT client
10. Fixed sometimes unable to access casgle web ui
11. Fixed HDD spin-up during standby
Note: Unzip into the root of your USB thumbdrive. Browse to usbupdate.html to update.
joe, si q ha tardado en salir la nueva versión respecto al a100. Habrán tenido algun problema gordo al hacer el cambio.
Pues si, no tenemos post-it de ello porque suele salir "al tiempo" y con las mismas features, pero parece que lo del tiempo está cambiando....
