# may/02/2022 18:28:57 by RouterOS 7.2.1
# software id = WI54-67LS
# model = RBD52G-5HacD2HnD
# serial number = E5780FB31926
/interface bridge
add admin-mac=DC:2C:6E:61:3E:4E auto-mac=no comment=defconf name=bridge
/interface wireless
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=CASA wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors installation=indoor mode=\
ap-bridge ssid=CASAPLUS wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
adslppp@telefonicanetpa
/interface wireguard
add listen-port=12345 mtu=1420 name=wireguard
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
/ip kid-control
add fri=0s-1d mon=0s-1d name=system-dummy sat=0s-1d sun=0s-1d thu=0s-1d tue=\
0s-1d tur-fri=0s-1d tur-mon=0s-1d tur-sat=0s-1d tur-sun=0s-1d tur-thu=\
0s-1d tur-tue=0s-1d tur-wed=0s-1d wed=0s-1d
/ip pool
add name=dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
add address-pool=dhcp interface=bridge lease-time=1h name=defconf
/interface bridge port
/interface list member
add list=LAN
add interface=wireguard list=LAN
/interface wireguard peers
add allowed-address=10.10.0.2/32 interface=wireguard public-key=\
"MLvDEKQXgepPxXOy1/JiYsVB8UvbSK8/ai9mNAqJYxQ="
192.168.88.0
add address=192.168.50.1/24 network=192.168.50.0
add address=10.10.0.1/24 interface=wireguard network=10.10.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
/ip dhcp-server network
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.88.1
/ip dns
set allow-remote-requests=yes use-doh-server=https://1.1.1.2/dns-query \
verify-doh-cert=yes
/ip dns static
invalid
add action=accept chain=input comment="vpn: allow wireguard" dst-port=12345 \
protocol=udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat disabled=yes dst-port=8080 in-interface=\
all-ppp protocol=tcp to-addresses=192.168.88.20 to-ports=8080
/ip kid-control device
add mac-address=4C:EB:BD:D8:3A:73 name="TV;-1"
add mac-address=1C:91:80:BE:2A:44 name="Macbook;-1"
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=0.0.0.0/24 disabled=yes
set ssh disabled=yes
set www-ssl port=4443
set api disabled=yes
set winbox address=192.168.88.10/32,10.10.0.2/32 port=11111
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system package update
set channel=development
/tool mac-server
/tool mac-server mac-winbox
