Postea la config, que lo vemos rápido.
Saludos, y bienvenido al club!
Ahí va la config. Por cierto, ¿hay alguna forma de ocultar los datos sensibles? o todo el mundo los quita a manurrio?
# apr/25/2022 19:56:36 by RouterOS 7.2.1
# software id = xxxxxxxx
# model = RBD53iG-5HacD2HnD
# serial number = XXXXXXXXXXXXX
/interface bridge
add admin-mac=2C:C8:1B:A0:AD:CD auto-mac=no comment=defconf name=bridge
/interface wireless
country=spain disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=XXXXXXXXXXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=spain disabled=no distance=indoors frequency=\
auto installation=indoor mode=ap-bridge ssid=XXXXXXXXXXXX \
/interface vlan
add interface=ether1 mtu=1492 name=vlan_internet vlan-id=6
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=adslppp@telefonicanetpa
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip pool
add name=dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
/ppp profile
/interface bridge port
/interface l2tp-server server
set enabled=yes use-ipsec=yes
/interface list member
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set enabled=yes
/interface sstp-server server
192.168.88.0
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.104 comment="Tuya Led" mac-address=18:69
8:4C:CA:99 \
server=defconf
add address=192.168.88.101 comment="Broadlink RM" mac-address=\
78:0F:77:17:EA:A9 server=defconf
add address=192.168.88.100 client-id=1:dc:a6:32:a9:cf:9c comment=\
"Home Assistant" mac-address=DC:A6:32:A9:CF:9C server=defconf
add address=192.168.88.102 client-id=1:cc:b1:1a:23:89:21 comment="TV Samsung" \
mac-address=CC:B1:1A:23:89:21 server=defconf
/ip dhcp-server network
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
192.168.89.0/24
add action=dst-nat chain=dstnat comment="NAT Home Assistant 8123 TCP" \
dst-port=8123 in-interface-list=WAN log=yes protocol=tcp src-port="" \
to-addresses=192.168.88.100 to-ports=8123
add action=dst-nat chain=dstnat comment="NAT Home Assistant 8123 UDP" \
dst-port=8123 in-interface-list=WAN log=yes packet-mark="" protocol=udp \
src-port="" to-addresses=192.168.88.100 to-ports=8123
add action=dst-nat chain=dstnat comment="NAT Home Assistant 443 TCP" \
dst-port=443 in-interface-list=WAN log=yes protocol=tcp src-port="" \
to-addresses=192.168.88.100 to-ports=443
add action=dst-nat chain=dstnat comment="NAT Home Assistant 443 UDP" \
dst-port=443 in-interface-list=WAN log=yes protocol=udp src-port="" \
add action=masquerade chain=srcnat comment="NAT LOOPBACK - Home Assistant" \
dst-address=192.168.88.100 dst-port=8123 out-interface-list=LAN protocol=\
tcp src-address=192.168.88.0/24
dst-address=192.168.88.100 dst-port=8123 log=yes out-interface-list=LAN \
protocol=udp src-address=192.168.88.0/24
dst-address=192.168.88.100 dst-port=443 log=yes out-interface-list=LAN \
protocol=tcp src-address=192.168.88.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=vpn
/system clock
/tool mac-server
/tool mac-server mac-winbox
