LTE con deco gorron
buenas, alguna ayuda para intentar resolver la cuestión que planteo, gracias. tengo el LTE configurado y con internet, tunel wireguard y EOIP conectado al donante, deco conectado a ETH2, coje la ip del donante pero cuando enciendo sale mensaje que no encuentra red, algo seguro que falta pero no lo detecto. envío configuración del LTE
# aug/08/2022 12:35:13 by RouterOS 7.4
# software id = Z68K-I2CK
# model = RBwAPGR-5HacD2HnD
# serial number = E1770F130C00
/interface bridge
add admin-mac=DC:2C:6E:FC:24:CE auto-mac=no comment=defconf igmp-snooping=yes \
    name=bridge
add name=ospf-lo
/interface lte
set [ find ] allow-roaming=no band=1,2,3,7,8,20,38,40 name=lte1
/interface wireless
    disabled=no distance=indoors frequency=auto installation=outdoor mode=\
    ap-bridge ssid=MikroTik-PLAYA wireless-protocol=802.11
/interface eoip
add keepalive=25s local-address=172.16.0.10 mac-address=02:A5:34:02:3A:E5 \
    mtu=1500 name=eoip-tunnel1 remote-address=172.16.0.6 tunnel-id=6
/interface wireguard
add listen-port=13500 mtu=1420 name=wireguard-casa
add listen-port=54521 mtu=1420 name=wireguard-compadre
add listen-port=13232 mtu=1420 name=wireguard-lte-juanma
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=airtelnet.es authentication=pap name=Vodafone \
    use-network-apn=no user=Vodafone
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=5g \
    supplicant-identity=""
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country=spain \
    default-authentication=no disabled=no distance=indoors frequency=5560 \
    installation=outdoor security-profile=5g skip-dfs-channels=all ssid=\
    MikroTik-FC24D1 station-roaming=enabled wds-default-bridge=bridge \
    wds-mode=dynamic-mesh wireless-protocol=802.11
/ip pool
add name=pool1 ranges=192.168.77.10,192.168.77.254
/ip dhcp-server
add address-pool=pool1 interface=bridge name=defconf
/routing ospf instance
add disabled=no name=v2 router-id=0.0.0.1
/routing ospf area
add disabled=no instance=v2 name=backbone
/routing table
add disabled=no fib name=tunel
/interface bridge port
add bridge=bridge comment=defconf interface=ether1
add bridge=bridge interface=eoip-tunnel1
/interface list member
add comment=defconf interface=lte1 list=WAN
add interface=wireguard-compadre list=LAN
add interface=wireguard-casa list=LAN
add interface=bridge list=LAN
add interface=wlan1 list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0,192.168.50.0/24 endpoint-address=\
    aaaf09501705.sn.mynetname.net endpoint-port=13500 interface=\
    wireguard-casa persistent-keepalive=25s public-key=\
    "Qnn9ZkeZCpNvn/g0K+xAyrIWlxAy0xArFDY="
add allowed-address=0.0.0.0/0,192.168.88.0/24 endpoint-address=\
    bd589.sn.mynetname.net endpoint-port=54521 interface=\
    wireguard-compadre persistent-keepalive=25s public-key=\
    "3AyoqN95Fidy4J7cg9s5n3Qv5uRbhP/SJDiE="
add allowed-address=0.0.0.0/0,192.168.1.0/24 endpoint-address=\
    d16938b.sn.mynetname.net endpoint-port=13232 interface=\
    wireguard-lte-juanma persistent-keepalive=25s public-key=\
    "e8gsWTyX6OgvhSnnJdzWpZmZ5PNlgzew8nzU="
add address=172.16.0.1/30 interface=wireguard-casa network=172.16.0.0
add address=172.16.0.10/30 interface=wireguard-compadre network=172.16.0.8
add address=192.168.77.1/24 interface=bridge network=192.168.77.0
add address=0.0.0.1 interface=ospf-lo network=0.0.0.1
/ip cloud
set ddns-enabled=yes
/ip cloud advanced
set use-local-address=yes
/ip dhcp-server network
add address=192.168.77.0/24 dns-server=192.168.77.1 gateway=192.168.77.1
/ip dns
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
    invalid
add action=accept chain=input protocol=gre
add action=accept chain=input dst-port=54421 protocol=udp
add action=accept chain=input dst-port=13220 protocol=udp
add action=accept chain=input dst-port=13500 protocol=udp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=change-ttl chain=postrouting new-ttl=set:65 out-interface=lte1 \
    passthrough=yes
/ip route
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.16.0.9 pref-src=\
    0.0.0.0 routing-table=tunel scope=30 suppress-hw-offload=no target-scope=\
    10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=14610
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing ospf interface-template
add area=backbone disabled=no networks=172.16.0.0/30,172.16.0.8/30 type=ptp
add area=backbone disabled=no networks=192.168.77.0/24 passive
/system clock
/system identity
set name=LTE-MAME
/tool mac-server
/tool mac-server mac-winbox
gracias.
    26.5 KB · Visitas: 60
    45.6 KB · Visitas: 59
    145.1 KB · Visitas: 52
@leptismame yo tuve hace un tiempo un Chateau 4G y no tuve narices a echar a andar el deco sobre ese router, ni con IPSec, ni con Wireguard.
Repasé la configuración "al dedillo" y no ví nada raro, el cliente DHCP cogía IP, pero no había forma...
Es curioso, porque esa misma SIM (Movistar datos ilimitados), con mismo APN, la instalo en un router MiFi, el cual conecto por USB a un RB750Gr3, y el deco va perfecto...
/interface bridge
    name=bridge
add name=ospf-lo
/interface lte
/interface wireless
/interface eoip
/interface list
/interface lte apn
/interface wireless
/ip pool
/ip dhcp-server
/routing ospf area
/routing table
    "XUjgc51qQnn9ZkeZCpNvn/g0K+xAyrIWlxAy0xArFDY="
    f43e0f4bd589.sn.mynetname.net endpoint-port=54521 interface=\
    "9I6YrEk3AyoqN95Fidy4J7cg9s5n3Qv5uRbhP/SJDiE="
    d1130d16938b.sn.mynetname.net endpoint-port=13232 interface=\
    "M6BOy9Ee8gsWTyX6OgvhSnnJdzWpZmZ5PNlgzew8nzU="
/ip cloud
/ip cloud advanced
/ip dns
/ip dns static
    invalid
/ip firewall mangle
    passthrough=yes
/ip route
    10
/ip service
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system identity
set name=LTE-MAME
/tool mac-server
gracias.
Tienes muchas cosas mal en esa configuración. Muchas, muchas. La más gorda: crear un conflicto de IPs con tu donante, al meter un EoIP en el mismo bridge sobre el que ya tienes un servidor dhcp corriendo, tu dhcp server local.
Repasa los manuales.
Pues vaya faena.
Me había hecho la ilusión de más adelante si podía hacerme con un Chateau LTE 4G y montar el "Pepe" en él para usar un deco y se me ha venido abajo el planteamiento con tu comentario.
De todas maneras es bueno saber que alguien lo ha intentado.
Y que con otro mikrotik más router lte por USB funciona.
Sí que es curioso, porque debería funcionar igual de las dos formas, incluso da la sensación de que debería funcionar mejor en el Chateau. Gracias por el feedback.
gracias por contestar, he creado un bridge-iptv, he metido eoip-tunnel y ether2 en el, el resto que tengo mal no lo detecto, "pocos conocimientos tengo para ello" y lo intento, pero¡¡, no soy capaz
Pues vaya faena.
Sí, te confirmo que con con MK + Router mifi LTE (o teléfono móvil) conectado por USB funciona perfectamente.
Es raro, pero yo no tuve narices de echar a andar el Chateau..., sin embargo, con la combinación que indicaba, a la primera...
Saludos.-
Vuelve a adjuntar el export, y lo vemos. La ruta por defecto que tenías puesta tampoco tenía sentido, puesto que estabas forzando que todo el tráfico de tu router, en lugar de salir por donde debe (la interfaz LTE), intente salir por otro lado. Además, si la wlan1 es WAN (o puede serlo en algún momento), no debe de estar nunca en el bridge.
La definición de la interfaz inalámbrica también tiene un popurrí de cosas interesantes:
Outdoor significa que vas a usar sí o sí DFS (los primeros canales se reservan para indoor) y luego le marcas que no quieres DFS. Además de eso, activas WDS, ¿para qué?
gracias por las molestias, la wifi wlan2 no la uso porque no tengo 5g, esa se creó sola con el quitset. con la configuración que envío tengo internet conectado a la wifi y el tunel eoip está RS, veo el deco en el router donante que la da ip. el osfp creo que está bién porque neigboard salen los dos. un saludo.
    21.9 KB · Visitas: 45
  • miercoles1.txt
    9.5 KB · Visitas: 47
Tienes mal el EoIP. Mira cómo defines la interfaz wireguard-compadre
Ese 172.16.0.10/30 significa que tú eres el .10, y por narices el otro extremos es el .9, que es la otra única IP usable de esa subred 172.16.0.8
Mira cómo defines el EoIP:
/interface eoip
El local address lo tienes bien, pero el remoto jamás va a poder ser una .6, puesto que no vas a llega nunca a esa IP si tu interfaz wireguard es la 172.16.0.10/30. Esa IP tiene que ser la remote-address=172.16.0.9
Por otro lado hay mucha config mejorable. Te pongo un par de ejemplos:
  • En los peers aceptas 0.0.0.0/0 (bien), pero también una subred más, la cual es totalmente redundante. Si aceptas tráfico de cualquier dirección de internet (eso significa 0.0.0.0/0), ¿para qué más?
  • En OSPF, puedes sumarizar las redes PTP: No pongas networks=172.16.0.0/30,172.16.0.8/30, pon networks=172.16.0.0/24, y las barres todas.
  • Sigo sin ver qué hace la routing table "tunel" que te tienes creada.
/interface eoip
gracias por el esfuerzo, ya he cambiado todo, tengo internet, veo el deco conectado al router de mi compadre, tunel eoip levantado, pero sigue el mensaje de no hay red.
así está ahora.
# aug/12/2022 20:29:35 by RouterOS 7.4.1
/interface bridge
    name=bridge
add igmp-snooping=yes name=bridge-iptv
add name=ospf-lo
/interface lte
set [ find ] allow-roaming=no band=3,20 name=lte1 network-mode=lte
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX distance=indoors frequency=auto installation=outdoor \
    mode=ap-bridge ssid=MikroTik-FC24D1 wireless-protocol=802.11
/interface eoip
    mtu=1500 name=eoip-tunnel1 remote-address=172.16.0.9 tunnel-id=6
/interface list
/interface lte apn
set [ find default=yes ] apn=orangeworld authentication=pap use-network-apn=\
    no user=orange
/ip pool
add name=dhcp_pool2 ranges=192.168.77.2-192.168.77.254
/ip dhcp-server
add address-pool=dhcp_pool2 interface=bridge name=dhcp1
/routing ospf area
add bridge=bridge-iptv comment=defconf interface=ether1
add bridge=bridge-iptv interface=eoip-tunnel1
add allowed-address=0.0.0.0/0 endpoint-address=aaaf09501705.sn.mynetname.net \
    endpoint-port=13500 interface=wireguard-casa persistent-keepalive=25s \
    public-key="XUjgc51qQnn9ZkeZCpNvn/g0K+xAyrIWlxAy0xArFDY="
add allowed-address=0.0.0.0/0 endpoint-address=f43e0f4bd589.sn.mynetname.net \
    endpoint-port=54521 interface=wireguard-compadre persistent-keepalive=25s \
    public-key="9I6YrEk3AyoqN95Fidy4J7cg9s5n3Qv5uRbhP/SJDiE="
/ip cloud
/ip cloud advanced
/ip dns
/ip dns static
    invalid
/ip firewall mangle
    passthrough=yes
/ip route
    0.0.0.0 routing-table=*400 scope=30 suppress-hw-offload=no target-scope=\
    10
/ip service
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
add area=backbone disabled=no networks=172.16.0.0/24 type=ptp
/system clock
/system identity
set name=LTE-MAME
/tool mac-server
Habría que ver la config del otro extremo también. Tu compadre qué tiene, HGU y un router tonto, o un mikrotik llevándolo todo?
¿qué IP le llega al desco?
Hola
Yo tengo un WapR fuincionando, solo con EoIP + ipsec
Te pongo mi configuracion por si te ayuda
Se pixela algo ya que la latencia que tengo de 55-60 ms, pero se ve razonablemente
Seguro que tendra errores, pero funciona
# aug/12/2022 23:43:20 by RouterOS 7.4
# software id = HSUE-XY4T
# model = RBwAPR-2nD
/interface bridge
add name=bridge-home
add name=bridge-local
/interface lte
set [ find ] allow-roaming=no band="" name=lte1 network-mode=3g,lte
/interface eoip
add allow-fast-path=no !keepalive name=\
EoIP-Uria remote-address=XXXXXXXXXXXXXX.sn.mynetname.net tunnel-id=101
/interface list
/interface lte apn
/ip pool
add name=dhcp ranges=192.168.87.10-192.168.87.254
/ip dhcp-server
add address-pool=dhcp interface=bridge-local name=dhcp-local
/routing bgp template
set default disabled=no output.network=bgp-networks
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge-home ingress-filtering=no interface=ether1 \
multicast-router=disabled
add bridge=bridge-local ingress-filtering=no interface=wlan1
add bridge=bridge-home interface=EoIP-Uria
/interface detect-internet
set detect-interface-list=WAN
add interface=lte1 list=WAN
add interface=bridge-local list=LAN
add interface=bridge-home list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.87.1/24 comment=defconf interface=bridge-local network=\
192.168.87.0
/ip cloud
/ip dhcp-client
add add-default-route=no interface=bridge-home
add address=192.168.87.0/24 comment=defconf dns-server=8.8.8.8,80.58.61.250 \
gateway=192.168.87.1 netmask=24
/ip dns
set allow-remote-requests=yes servers=1.1.1.2,1.0.0.2
/ip dns static
add address=192.168.87.1 comment=defconf name=roaming.lan
/ip firewall address-list
add address=XXXXXXXXXXXXX.sn.mynetname.net list=Uria
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes log-prefix=fasttrack
add action=accept chain=input src-address-list=Uria
add action=masquerade chain=srcnat comment=home-router-masq. dst-address=\
0.0.0.0/0 out-interface=lte1 src-address=192.168.87.0/24
/ip route
add disabled=no distance=1 dst-address=192.168.15.0/24 gateway=192.168.255.1 \
pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10 vrf-interface=*7
/system clock
/system identity
set name=WAPr_GarciaConde
Acabo de probar el setup LTE y es perfectamente posible. ¿Principal problema? Tener un tráfico sostenido de 10Mbps (lo que más o menos necesitas para que esto tire, 7Mbps se come como poco el canal 0 de bienvenida, el de la musiquita) es complejo para una interfaz LTE, a menos que tengas una señal excelente.
Los túneles levantan, el EoIP está a RS, recibo IP del otro extremo, la tabla MDB del bridge se llena de IPs multicast... pero sencillamente el LTE no da de sí como para que esto tire.
Sospecho que te está pasando lo mismo.
¿Que latencia tienes con el LTE?
Unos 50ms. Pero la latencia es lo de menos en este setup, si no eres capaz de tener un flujo continuo de tráfico sobre esa conexión WAN. Fijaos en el tráfico sostenido que tiene el multicast. No se menea ni gota...
Si no eres capaz de mantener ese flujo o superior, no vas a poder ver esto. No hay más chicha ni más limoná. No tiene nada que ver que sea LTE o no (cuando tenga una buena conectividad LTE con CA, lo pruebo si queréis).
Ver el adjunto 98007
    55.8 KB · Visitas: 64
Hola
El lte parece sostener el trafico igual que la fibra, pero la tv se pixela mucho más en el lte que en la fibra
Las gráficas son identicas, mismos picos y mismos valles
Ver el adjunto 98025
Eso sí tiene sentido, debido al tipo de conexión. Pero que no se vea por LTE, por el mero hecho de serlo, es lo que no me cuadra.
