Ayuda con el siguiente SCRIPT muchachos
Tengo el siguiente script y me funciona muy bien
:global interfaceIP "ETHERT 1"
:global filenameIP "iphistory.txt"
:global arrMonths {jan="01";feb="02";mar="03";apr="04";may="05";jun="06";jul="07";aug="08";sep="09";oct="10";nov="11";dec="12"}
:local data [/system clock get date]
:local itime [/system clock get time]
:local hours [:pick $itime 0 2]
:local minsec [:pick $itime 2 8]
:local mhours [:tonum $hours]
:local msymbl "AM"
:if ($mhours > 11) do={:set msymbl "PM"}
:set mhours ($mhours % 12)
:if ($mhours = 0) do={:set mhours 12}
:if ($mhours < 10) do={:set mhours "0$mhours"}
:local mtime "$mhours$minsec $msymbl"
:global now "HORA:$mtime FECHA: $[:pick $data 4 6]-$($arrMonths->[:pick $data 0 3])-$[:pick $data 7 11]"
/file
:if ([:len [find where name="flash" and type="disk"]] = 1) do={:set filenameIP "flash/$filenameIP"}
:if ([:len [find where name=$filenameIP]] = 0) do={print file="$filenameIP"; :delay 5s; set $filenameIP contents=""}
:global currentIP
:if ([:len $currentIP] = 0) do={:set currentIP 0.0.0.0/0}
:local newIP [/ip address get [find interface="$interfaceIP"] address]
:set newIP [:pick $newIP 0 [:find $newIP "/" -1]]
:if ($newIP != $currentIP) do={
/file
:delay 5s
:local filecontent [get $filenameIP contents]
:local newfilecontent "NUEVA IP:$newIP\t$now\r\n$filecontent"
set $filenameIP contents=$newfilecontent
:set currentIP $newIP;
el problema lo tengo cuando hay algun corte electrico prolongado y el Routerboard no sincroniza la hora actual pasa lo siguiebte:
NUEVA IP:190.78.186.59 HORA:05:36:10 PM FECHA: 15-04-2022
NUEVA IP:186.95.45.220 HORA:04:17:51 PM FECHA: 06-04-2022
NUEVA IP:186.95.84.150 HORA:04:11:51 PM FECHA: 15-04-2022
NUEVA IP:186.95.13.112 HORA:03:48:20 PM FECHA: 15-04-2022
NUEVA IP:186.95.84.150 HORA:03:48:00 PM FECHA: 15-04-2022
NUEVA IP:186.95.45.220 HORA:12:03:40 PM FECHA: 15-04-2022
NUEVA IP:190.72.12.81 HORA:12:02:10 PM FECHA: 15-04-2022
NUEVA IP:186.95.13.112 HORA:12:01:10 PM FECHA: 14-04-2022
NUEVA IP:190.72.12.81 HORA:11:34:20 AM FECHA: 14-04-2022
como haria para que no registre en el archivo la ultima fecha en que se reinicio el RB? O sea la linea roja. Gracias por su ayuda.
Pon un cliente NTP a funcionar, tal que lo primero que haga el router al arrancar se sincronizar fecha/hora desde internet.
Si tienes activado IP -> Cloud, y marcada la opción "update time", se actualizará sólo. Eso en sí, ya es un cliente NTP.
Si ese no te da la hora lo suficientemente rápido, cámbialo por otro. Ejemplo:
/system ntp client
set enabled=yes
/system ntp client servers
add address=es.pool.ntp.org
Si estás en España, ese pool. Si estás en otro país, el que sea de tu país: www.pool.ntp.org
y tienes configurado en esa version un NTP Client alli?
yo tengo la version 6.49.4
¿Allí donde, en mi router? Sí, el que te mando, tal y como te lo mando. Tan pronto el equipo reinicia y se conecta a internet, corrige la hora, si se ha desincronizado.
y que mejoras tiene la version 7 con respecto a la version 6 amigo?
tengo un RB 750GL, me recomiendas actualizarlo a version 7?
