knario75
Usuari@ ADSLzone
- 191
Buenos dias, Quisiera poder instalarle a mi hermana un Hap-ac que tenía por aquí en un cajón.
Hoy me he aventurado y no consigo que me funcione el teléfono. La compañia es O2
Internet si va , seguramente en un pequeño apartado en winbox que se me pasa por alto.
Subo la config por si alguien ve dónde está el problema. Múchisimas gracias y feliz dia.
# dec/28/2021 11:20:38 by RouterOS 7.1.1
# software id = XGDW-6A8U
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7C08BA2366
/interface bridge
add admin-mac=CC:2D:E0:C4:58:59 auto-mac=no comment=defconf name=bridge
/interface wireless
country=spain disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=Noelia wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=spain disabled=no distance=indoors frequency=\
auto installation=indoor mode=ap-bridge ssid=Noelia \
/interface vlan
add interface=ether1 name=vlan3 vlan-id=3
add interface=ether1 name=vlan6 vlan-id=6
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan6 max-mru=1492 max-mtu=\
1492 name=pppoe-out1 use-peer-dns=yes user=adslppp@telefonicanetpa
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=hotspot
/ip pool
add name=dhcp ranges=192.168.2.10-192.168.2.254
/ip dhcp-server
/routing rip instance
/interface bridge port
/interface list member
add address=192.168.2.1/24 comment=defconf interface=bridge network=\
192.168.2.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no interface=vlan3 use-peer-ntp=no
/ip dhcp-server network
add address=192.168.2.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.2.1 netmask=24
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.2.1 comment=defconf name=router.lan
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=4 out-interface=vlan3
pppoe-out1
add action=masquerade chain=srcnat comment="masq. voip" out-interface=vlan3
/ip firewall service-port
set sip disabled=yes ports=5060,5070
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rip interface-template
add disabled=no instance=rip interfaces=vlan3 mode=passive
/system clock
/tool mac-server
/tool mac-server mac-winbox
