robermgs
Usuari@ ADSLzone
- 8
Pero no te lo da cifrado?Desde samba no he podido hacer nada. Me ha tocado abrir el router y sacarlo a través del puerto serie. Así se puede sacar TODO![]()
Pero todo lo cifrado se puede descifrarPero no te lo da cifrado?
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Auxillary File System Size Percent: 0
Main Thread Number [0|1] : 0
MC memory allocation (MB) : 4
TM memory allocation (MB) : 20
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 111
Creating CPU ring for queue number 0 with 32 packets descriptor=0x80671a84
Done initializing Ring 0 Base=0xa220f720K End=0xa220f920K calculated entries= 32 RDD Base=0x0220f720K descriptor=0x80671a84
Open PHY 1 on MAC 0 : link state = Down
Open PHY 2 on MAC 1 : link state = Down
Open PHY 3 on MAC 2 : link state = Down
Open PHY 4 on MAC 3 : link state = Down
CFE>
web info: Waiting for connection on socket 0.[J
CFE>
CFE> help
Available commands:
dn Dump NAND contents along with spare area
phy Set memory or registers.
sm Set memory or registers.
dm Dump memory or registers.
serial serial <open/close> in the cfe
downver Download and flash images in ZTE ver
w Write the whole image start from beginning of the flash
e Erase NAND flash
ws Write whole image (priviously loaded by kermit) to flash .
r Run program from flash image or from host depend on [f/h] flag
p Print boot line and board parameter info
c Change booline parameters
i Erase persistent storage data
a Change board AFE ID
b Change board parameters
testddr Test ddr chip
reset Reset the board
pmdio Pseudo MDIO access for external switches.
spi Legacy SPI access of external switch.
force override chipid check for images.
help Obtain help for CFE commands
For more information about a command, enter 'help command-name'
*** command status = 0
CFE>
CFE> serial open
Write Success SerialEnable=1
CFE>
CFE> reset
Resetting board in 0 seconds...ÿHELO
Hola tengo la versión HW V4.0, SW ZTEGF6804P1T27
Confirmo que en mi caso la vulnerabilidad de samba ya no funciona. En cuanto al serie, cuando te conectas al rato se deshabilita. Por ahora he descubierto que nada más arrancar puedes parar el bootloader pulsando cualquier tecla:
Código:... ... Enable Backup PSI [0|1] : 0 System Log Size (0-256) KBytes : 0 Auxillary File System Size Percent: 0 Main Thread Number [0|1] : 0 MC memory allocation (MB) : 4 TM memory allocation (MB) : 20 *** Press any key to stop auto run (1 seconds) *** Auto run second count down: 111 Creating CPU ring for queue number 0 with 32 packets descriptor=0x80671a84 Done initializing Ring 0 Base=0xa220f720K End=0xa220f920K calculated entries= 32 RDD Base=0x0220f720K descriptor=0x80671a84 Open PHY 1 on MAC 0 : link state = Down Open PHY 2 on MAC 1 : link state = Down Open PHY 3 on MAC 2 : link state = Down Open PHY 4 on MAC 3 : link state = Down CFE> web info: Waiting for connection on socket 0.[J
aparece "CFE>" que es la terminal del bootloader. Puedes hacer help como en uboot para ver los comandos y activar el serie con "serial open" y luego le haces un reset:
Código:CFE> CFE> help Available commands: dn Dump NAND contents along with spare area phy Set memory or registers. sm Set memory or registers. dm Dump memory or registers. serial serial <open/close> in the cfe downver Download and flash images in ZTE ver w Write the whole image start from beginning of the flash e Erase NAND flash ws Write whole image (priviously loaded by kermit) to flash . r Run program from flash image or from host depend on [f/h] flag p Print boot line and board parameter info c Change booline parameters i Erase persistent storage data a Change board AFE ID b Change board parameters testddr Test ddr chip reset Reset the board pmdio Pseudo MDIO access for external switches. spi Legacy SPI access of external switch. force override chipid check for images. help Obtain help for CFE commands For more information about a command, enter 'help command-name' *** command status = 0 CFE> CFE> serial open Write Success SerialEnable=1 *** command status = 0 CFE> CFE> reset Resetting board in 0 seconds...ÿHELO
Y ya booteo pero tengo login incorrect con root/root así que no puedo acceder a la consola del kernel xD
También he probado el telnet, que está habilitado pero no funciona la mítica root/Zte521
Estoy un poco enrocado porque el servidor web tiene también capado cargar un firmware previo:
Ver el adjunto 73195
Como véis, ha desaparecido la pestaña de poner un back-up. He llamado a los de Pepephone, que como muchas operadoras no quieren proporcionarme mis datos... Una pena... para ellos, porque con esto así voy a tardar poco en cambiarme de compañía![]()
Los que os estáis conectando al puerto serie y os sale el usuario "qantenna", no os estáis conectando al lugar correcto. Os estáis conectando directamente a la interfaz del chip Wi-Fi y, desde ahí no podréis hacer nada.
En algunos modelos, el puerto serie correcto es el que no tiene los pines soldados. Es decir, que vais a tener que utilizar estaño y un soldador bien hermoso.
Entonces este método aún funciona con los firmwares nuevos ???
Gracias y saludos
Hola. He visto que al final solucionaste el problema. Puedes contar cómo has hecho? Es por ir pidiendo el USB ttl para hacer lo mismo. Ya que parece que tú versión de firm/hard es la que tenemos todos los de Yoigo.Hola de nuevo!
Tengo un ZTE F680 V4 con firm ZTEGF6804P1T27 y os aseguro que ya no funciona el bug Samba. Lo he probado en un V2 y el pincho usb / bug funciona a las mil maravillas pero en el V4 no; da un error de "Acceso denegado". Puede que lo hayan parcheado o el fichero de configuración samba este en otro path diferente.
He ido a acceder por el puerto serie USB/TTL; y al principio me salia la información del boot y luego se silenciaba la salida. He visto que en el CFE se puede habilitar el puerto serie no solo para el boot, sino para todo el rato (uff, menos mal).
Total que he llegado al prompt del login y ... SORPRESA!! Las contraseñas root/root y root/Zte521(esta es la que me funcionaba en la V2) no funcionan¿Alguien puede echarme un cable?
Cosas que se me ocurren:
* Hacer downgrade del firmware. Se como hacerlo pero no he conseguido ninguna imagen por ahí. ¿Alguien puede pasarmelo?
* Hacer un dump de toda la flash. Estoy en ello. Mi idea es extraer el etc/shadow para ver que password le han puesto ahora.
* ¿Alguna otra sugerencia?
Saludos!!!
He acabado decifrar el config con routerpassview - https://routerpassview.en.lo4d.com/windows pero he cambiado la fibra a GUUK que me han prometido revelar las claves. Todavia estoy esperandolos, pero estoy de momento fuera de España por Corona. Quiero poner mi Fritzbox 5491 en vez del ruter sagecom que tambien es años de luz atras.Pero no te lo da cifrado?
